Perspective messageBox Ignition 8
Hey Guys,
I have been playing around with system.perspective.sendMessage but it has not been working. I am still trying to understand the parameters to that function.
I’ve been poking at this for quite a while but is there any system.gui.messageBox alternative in perspective?
Thank you for your time.
Regards,
Delbert Edric
I think what you're looking for is system.perspective.openPopup()
You would create a view (a coordinate container for example) and just reference that view when you call openPopup.
Link for other parameters to get fancy:
edit: updated doc link.
I understood that to use this openPopup function there is the need to create a new view with the message. Is that right?
But I'd like to simply show a message, I don't want to have a new view for this.
In vision, it would simply be: system.gui.messageBox.
What is the alternative for this in Perspective?
Thanks.
There is no alternative for this in Perspective. Create a view for this purpose.
{ You should also avoid using those simple popups in Vision--they block all foreground threads while open. That can have surprisingly negative consequences. }
