I need to produce a scatter chart in ignition “perspective view”. but I can’t find the components help to me.
This is my example. X axis is Hz , Y axis is kW.
XYChart with
this.props.series[X].line.appearance.bullets[X].enabled set True and
this.props.series[X].line.appearance.stroke.width set 0
XYChart I tried.but this isn’t waht my need.The X axis is datetime.
I need X/Y axis both can input value.
Example:
[10,50],[11,30],[9,65],[15,80],[8,60]…
The Y axis can be any type you need it to be. You have to change the properties.
Change the Y axis render from Date to Value.
The XYChart is the correct component for your requirements.
