Perspective Multi Monitor on Ultrawide
Any way to configure multi-monitor setup for only one ultrawide monitor?
Probably best to create a new topic for your specific question.
Hi @Henrik_Jensen,
If you create a new view of the size of your ultra wide monitor and you then embedded the needed views inside You can then call this new view as startup view
The way of navigate between views would need to be changed
Regards
I think either your monitor or some 3rd party software would need to make it so the OS saw multiple monitors.
Otherwise you’ll need to simulate / workaround it by maybe doing something like @Arnaud_Declerck suggested.
