Perspective - New Session Email Alert
Hi there,
Is there any way to set up an email notification to be sent when a user starts an Perspective session?
I was thinking of using the audit logs “login” action column as a starting place but any other ideas would be welcome.
Thanks,
Mike.
You could use system.net.sendEmail(), assuming you have an SMTP server configured.
You just need to insert that call into the Script portion of a Session Startup Event (Project > Session Events > Startup).
Thanks for the quick response. This worked perfectly!
