Perspective Not Showing
I don’t think that will help. I think there’s still something environmental that’s causing issues. I’m just not sure what. I’m still leaning towards something security/permissions related.
I attempted to do the same, @avaughn is correct. Nothing changed for me either.
I just reinstalled and opened a new project. I see this error that caught my eye. Does this have anything related?
Can you copy out the full text again?
This is just at the beginning of the output console:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.inductiveautomation.ignition.designer.i18n.DesignerLocalizationManager.addLocaleListener(com.inductiveautomation.ignition.client.model.LocaleListener)" because the return value of "com.inductiveautomation.ignition.designer.IgnitionDesigner.getLocalizationManager()" is null
	at com.inductiveautomation.ignition.designer.DesignerStartupHook.lambda$startup$1(DesignerStartupHook.java:333)
	at java.base/java.security.AccessController.doPrivileged(Unknown Source)
09:29:00.491 [Designer-Startup] INFO designer.main -- Downloading... [+0]
09:29:00.527 [Designer-Startup] INFO designer.main -- Cleanup... [+36]
09:29:00.538 [Designer-Startup] INFO designer.main -- Initializing UI... [+47]
09:29:00.585 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
09:29:03.407 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+2916]
09:29:04.758 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module.  Mode: Trial
9:29:04.810 DEBUG Creating directory: C:\Users\rhull\.ignition\cache\resources\jxbrowser\8.5.0
9:29:04.811 DEBUG Acquiring an exclusive lock...
9:29:04.812 DEBUG Acquiring an exclusive lock...
9:29:04.812 DEBUG Checking binaries integrity in C:\Users\rhull\.ignition\cache\resources\jxbrowser\8.5.0...
9:29:04.814 DEBUG Using WIN64 listing...
9:29:04.869 DEBUG Checked C:\Users\rhull\.ignition\cache\resources\jxbrowser\8.5.0\libEGL.dll: File does not exist.
9:29:04.874 DEBUG Using WIN32 listing...
9:29:04.918 DEBUG Checked C:\Users\rhull\.ignition\cache\resources\jxbrowser\8.5.0\libEGL.dll: File does not exist.
9:29:04.921 DEBUG Checking binaries integrity... [FAIL]
9:29:04.921 DEBUG Finding Chromium binaries in JARs...
9:29:04.923 DEBUG Finding chromium-win64.7z...
9:29:04.924 DEBUG Extracting Chromium binaries...
9:29:07.521 DEBUG
9:29:07.521 INFO
7-Zip (r) 24.08 (x86) : Igor Pavlov : Public domain : 2024-08-11
Scanning the drive for archives:
1 file, 110292735 bytes (106 MiB)
Extracting archive: C:\Users\rhull\.ignition\cache\resources\jxbrowser\8.5.0\chromium-win64.7z
Path = C:\Users\rhull\.ignition\cache\resources\jxbrowser\8.5.0\chromium-win64.7z
Type = 7z
Physical Size = 110292735
Headers Size = 1716
Method = LZMA2:24 BCJ
Solid = +
Blocks = 2
Everything is Ok
Folders: 2
Files: 136
Compressed: 110292735
Were you ever able to successfully delete the cache directory?
Yes, however I just uninstalled and reinstalled Ignition
Okay. Uninstalling/reinstalling doesn’t remove the .ignition directory, so it needs to be done separately.
Those log messages are complaining about missing files. If you check .ignition\cache\resources\jxbrowser\8.5.0 do you see the libEGL.dll file?
Yes I see them
Can you create a text file in the .ignition directory named redirect.txt that contains a single line with an absolute path to a new folder in either Documents or Downloads. This folder will be the new destination to create the cache and download resources too.
Prior to doing this, go ahead and close all designers and designer launchers and then reopen the designer launcher after and re-add the gateway to attempt launching again.
Something like this right?
I don’t think it will work with the quotes around the path but other than that it looks correct.
I readded the gateway to the designer, however, perspective is still no longer present. Am I missing something?
Are you still getting the file not found errors? If so, and the files show in the folder, then there's some permissions error still present. Perhaps how the launcher is installed.
Can you try a folder that’s not within Onedrive and see if that changes anything? Also, can you re-add the debug logging argument before launching. Then copy out the console contents if it still doesn’t work so we can compare to the previous attempts.
It does seem to most likely be permissions related though so you may have to involve your IT department and see if there might be something with the way the User accounts are configured.
This is what I got when I have the file in the Documents folder
11:54:57.844 [WebSocket@1982031061-50] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager -- WebSocket session is connected
11:56:07.766 [Designer-Startup] INFO designer.main -- Downloading... [+0]
11:56:07.808 [Designer-Startup] INFO designer.main -- Cleanup... [+42]
11:56:07.813 [Designer-Startup] INFO designer.main -- Initializing UI... [+47]
11:56:07.865 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
11:56:09.089 [Designer-Startup] INFO designer.main -- Starting module: Vision [+1323]
11:56:09.406 DEBUG Acquiring an exclusive lock...
11:56:09.407 DEBUG Acquiring an exclusive lock...
11:56:09.408 DEBUG Checking binaries integrity in C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0...
11:56:09.409 DEBUG Using WIN64 listing...
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\libEGL.dll
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-TW.pak.info
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chrome_200_percent.pak
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\cs.pak
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ar.pak.info
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\th.pak.info
11:56:09.469 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ml.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\af.pak.info
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\resources.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chrome.dll.sig
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\nl.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ca.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\vi.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\uk.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ro.pak
11:56:09.470 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-US.pak
11:56:09.471 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sv.pak
11:56:09.471 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\awt_toolkit64.dll
11:56:09.471 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\bn.pak
11:56:09.471 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\da.pak
11:56:09.471 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\MEIPreload\\manifest.json
11:56:09.471 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\libGLESv2.dll
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\toolkit32.dll
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-PT.pak
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\kn.pak
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\MEIPreload\\preloaded_data.pb
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\am.pak.info
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chromium.version
11:56:09.472 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ms.pak
11:56:09.473 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ur.pak
11:56:09.473 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sk.pak
11:56:09.473 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\hr.pak.info
11:56:09.473 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fi.pak.info
11:56:09.473 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ar.pak
11:56:09.473 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\id.pak.info
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\es-419.pak.info
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\pl.pak
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\id.pak
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\el.pak
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\he.pak.info
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\mr.pak
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ta.pak.info
11:56:09.474 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ms.pak.info
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\vulkan-1.dll
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\bg.pak.info
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fi.pak
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sr.pak
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\es.pak
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fr.pak
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\th.pak
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\tr.pak.info
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-US.pak.info
11:56:09.475 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\et.pak.info
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\lv.pak
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sv.pak.info
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\ipc64.dll
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe.sig
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-GB.pak.info
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\vk_swiftshader_icd.json
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ru.pak.info
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fr.pak.info
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ko.pak.info
11:56:09.476 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ca.pak.info
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\pl.pak.info
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fil.pak
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\de.pak
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\lt.pak
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ml.pak.info
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-TW.pak
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\it.pak
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fa.pak.info
11:56:09.477 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chrome.dll
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\am.pak
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\awt_toolkit32.dll
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sl.pak.info
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\hu.pak
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sr.pak.info
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ta.pak
11:56:09.478 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\el.pak.info
11:56:09.479 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-GB.pak
11:56:09.479 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\ipc32.dll
11:56:09.479 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\hi.pak.info
11:56:09.479 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\nb.pak
11:56:09.479 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sw.pak
11:56:09.479 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\te.pak.info
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\cs.pak.info
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ko.pak
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\vi.pak.info
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\gu.pak
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\toolkit64.dll
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\uk.pak.info
11:56:09.480 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-PT.pak.info
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\d3dcompiler_47.dll
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\es-419.pak
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ja.pak
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\it.pak.info
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\134.0.6998.89.manifest
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\da.pak.info
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\gu.pak.info
11:56:09.481 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\te.pak
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\he.pak
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\bn.pak.info
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-BR.pak.info
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chrome_elf.dll
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ur.pak.info
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-CN.pak
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\de.pak.info
11:56:09.482 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fil.pak.info
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\bg.pak
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\es.pak.info
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\et.pak
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sw.pak.info
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\vk_swiftshader.dll
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\nl.pak.info
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-BR.pak
11:56:09.483 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\fa.pak
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\lt.pak.info
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\af.pak
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\hi.pak
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chrome_100_percent.pak
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\nb.pak.info
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\icudtl.dat
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\mr.pak.info
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\v8_context_snapshot.bin
11:56:09.484 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\tr.pak
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ja.pak.info
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\hr.pak
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\lv.pak.info
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\hu.pak.info
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\sk.pak.info
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\kn.pak.info
11:56:09.485 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ro.pak.info
11:56:09.486 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-CN.pak.info
11:56:09.486 DEBUG Checked C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\locales\\ru.pak
11:56:09.489 DEBUG Checking binaries integrity... [OK]
11:56:09.492 DEBUG Releasing the exclusive lock...
11:56:09.495 DEBUG Starting server...
11:56:09.498 DEBUG Starting server at port 55423... [OK]
11:56:09.501 DEBUG Accepting connections...
11:56:09.528 DEBUG Starting chromium process...
11:56:09.529 DEBUG __COMPAT_LAYER variable detected: ElevateCreateProcess
11:56:09.531 DEBUG C:\Users\rhull\OneDrive - *****\Documents\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe --port=55423 --pid=26292 --browsercore --no-default-browser-check --off-screen --lang=en-us --remote-debugging-port=9222 --hung-render-delay-seconds=15 --incognito --proprietary-features=0 --user-data-dir=C:\Users\rhull\AppData\Local\Temp\JxBrowser-UserData-e2ab93ac-ea5d-41d1-bef1-94d3d41c6b37 --dpi-awareness=per-monitor-aware --disable-fill-background --disable-direct-composition --crash-dump-dir=C:\Users\rhull\AppData\Local\JxBrowser\8.5.0\CrashReports --disable-background-networking --disable-sync --disable-features=OptimizationHintsFetching --disable-component-update --do-not-de-elevate
11:56:09.549 DEBUG Starting chromium process... [OK]
11:56:09.716 DEBUG [Chromium] [0820/115609.716:INFO:compatibility_mode.cc(86)] Actual Windows version: 10.0.26100
11:56:09.716 DEBUG [Chromium] [0820/115609.716:INFO:compatibility_mode.cc(93)] Simulated Windows version: 10.0.26100
11:56:09.717 DEBUG [Chromium] [0820/115609.716:INFO:compatibility_mode.cc(62)] Compatibility environment variable: ElevateCreateProcess
11:56:09.767 DEBUG Accepting connection...
11:56:09.782 DEBUG RPC thread started: id = 102, type = BROWSER
11:56:09.844 DEBUG Accepted: RpcConnection [id = 8ffdf199-4a92-416c-99ce-e50ae0082dbe; type = BROWSER]
11:56:09.846 DEBUG Product binding call stack:
java.lang.Thread
com.teamdev.jxbrowser.engine.internal.EngineImpl
com.teamdev.jxbrowser.engine.Engine
com.inductiveautomation.ignition.client.util.JxBrowserUtil
com.inductiveautomation.webbrowser.BrowserInstanceManager
com.inductiveautomation.factorypmi.application.FPMIApp
com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl
com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule
com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler
java.lang.Thread
11:56:09.883 DEBUG [Chromium] [17424:24432:0820/115609.883:WARNING:account_consistency_mode_manager.cc(77)] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
11:56:09.901 DEBUG > [1:69]: rpc.EngineFactory.ApplyLicense [product_name: "JxBrowser" product_version: "8.5.0" stack_trace: ***** key: *****]
11:56:10.028 DEBUG [Chromium] [7312:5384:0820/115610.028:WARNING:viz_main_impl.cc(85)] VizNullHypothesis is disabled (not a warning)
11:56:10.029 DEBUG [Chromium] [7312:5384:0820/115610.028:INFO:content_gpu_client.cc(47)] ContentGpuClient::PostCompositorThreadCreated
11:56:10.100 DEBUG Closing RPC thread...
11:56:10.100 DEBUG The connection has been terminated.
11:56:10.100 DEBUG Closing RPC thread... [OK]
11:56:10.111 DEBUG Chromium process exit code: -2,147,483,645
11:56:10.132 DEBUG Stopping server...
11:56:10.132 DEBUG Stopping server... [OK]
and the crash file reported:
I moved the new cache to my c drive on my machine. Here is the error I get this time
14:22:43.188 [Designer-Startup] INFO designer.main -- Downloading... [+0]
14:22:43.222 [Designer-Startup] INFO designer.main -- Cleanup... [+34]
14:22:43.230 [Designer-Startup] INFO designer.main -- Initializing UI... [+42]
14:22:43.287 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
14:22:46.101 [Designer-Startup] INFO designer.main -- Starting module: Vision [+2913]
14:22:46.466 DEBUG Creating directory: C:\newCache\cache\resources\jxbrowser\8.5.0
14:22:46.469 DEBUG Acquiring an exclusive lock...
14:22:46.470 DEBUG Acquiring an exclusive lock...
14:22:46.471 DEBUG Checking binaries integrity in C:\newCache\cache\resources\jxbrowser\8.5.0...
14:22:46.472 DEBUG Using WIN64 listing...
14:22:46.533 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\libEGL.dll: File does not exist.
14:22:46.537 DEBUG Using WIN32 listing...
14:22:46.580 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\libEGL.dll: File does not exist.
14:22:46.583 DEBUG Checking binaries integrity... [FAIL]
14:22:46.583 DEBUG Finding Chromium binaries in JARs...
14:22:46.585 DEBUG Finding chromium-win64.7z...
14:22:46.586 DEBUG Extracting Chromium binaries...
14:22:49.168 DEBUG
14:22:49.168 INFO
Extracting archive: C:\newCache\cache\resources\jxbrowser\8.5.0\chromium-win64.7z
Path = C:\newCache\cache\resources\jxbrowser\8.5.0\chromium-win64.7z
Type = 7z
Headers Size = 1716
Solid = +
Blocks = 2
Everything is Ok
Folders: 2
Files: 136
14:22:49.169 [XZ Logger (out)] INFO com.teamdev.jxbrowser --
Type = 7z
Headers Size = 1716
Solid = +
Blocks = 2
Everything is Ok
Folders: 2
Files: 136
14:22:49.181 DEBUG Extracting Chromium binaries... [OK] 2,595ms
14:22:49.181 DEBUG Checking binaries integrity in C:\newCache\cache\resources\jxbrowser\8.5.0...
14:22:49.181 DEBUG Using WIN64 listing...
14:22:49.226 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\libEGL.dll
14:22:49.226 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-TW.pak.info
14:22:49.226 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome_200_percent.pak
14:22:49.226 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\cs.pak
14:22:49.226 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ar.pak.info
14:22:49.226 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\th.pak.info
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ml.pak
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\af.pak.info
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\resources.pak
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome.dll.sig
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nl.pak
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ca.pak
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\vi.pak
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\uk.pak
14:22:49.227 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ro.pak
14:22:49.228 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-US.pak
14:22:49.228 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sv.pak
14:22:49.228 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\awt_toolkit64.dll
14:22:49.228 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bn.pak
14:22:49.228 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\da.pak
14:22:49.228 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\MEIPreload\\manifest.json
14:22:49.229 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\libGLESv2.dll
14:22:49.229 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\toolkit32.dll
14:22:49.229 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-PT.pak
14:22:49.229 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\kn.pak
14:22:49.229 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\MEIPreload\\preloaded_data.pb
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\am.pak.info
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.version
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ms.pak
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ur.pak
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sk.pak
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hr.pak.info
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fi.pak.info
14:22:49.230 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ar.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\id.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es-419.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pl.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\el.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\he.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\mr.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ta.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ms.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\vulkan-1.dll
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bg.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fi.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sr.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fr.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\th.pak
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\tr.pak.info
14:22:49.231 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-US.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\et.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lv.pak
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sv.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\ipc64.dll
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe.sig
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-GB.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\vk_swiftshader_icd.json
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ru.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fr.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ko.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ca.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pl.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fil.pak
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\de.pak
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lt.pak
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ml.pak.info
14:22:49.232 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-TW.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\it.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fa.pak.info
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome.dll
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\am.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\awt_toolkit32.dll
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sl.pak.info
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hu.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sr.pak.info
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ta.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\el.pak.info
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-GB.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\ipc32.dll
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hi.pak.info
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nb.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sw.pak
14:22:49.233 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\te.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\cs.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ko.pak
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\vi.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\gu.pak
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\toolkit64.dll
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\uk.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-PT.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\d3dcompiler_47.dll
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es-419.pak
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ja.pak
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\it.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\134.0.6998.89.manifest
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\da.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\gu.pak.info
14:22:49.234 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\te.pak
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\he.pak
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bn.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-BR.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome_elf.dll
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ur.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-CN.pak
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\de.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fil.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bg.pak
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\et.pak
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sw.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\vk_swiftshader.dll
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nl.pak.info
14:22:49.235 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fa.pak
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lt.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\af.pak
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hi.pak
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome_100_percent.pak
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nb.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\icudtl.dat
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\mr.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\v8_context_snapshot.bin
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\tr.pak
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ja.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hr.pak
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lv.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hu.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sk.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\kn.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ro.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-CN.pak.info
14:22:49.236 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ru.pak
14:22:49.238 DEBUG Checking binaries integrity... [OK]
14:22:49.238 DEBUG Releasing the exclusive lock...
14:22:49.242 DEBUG Starting server...
14:22:49.243 DEBUG Starting server at port 55698... [OK]
14:22:49.244 DEBUG Accepting connections...
14:22:49.258 DEBUG Starting chromium process...
14:22:49.258 DEBUG __COMPAT_LAYER variable detected: ElevateCreateProcess
14:22:49.259 DEBUG C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe --port=55698 --pid=26848 --browsercore --no-default-browser-check --off-screen --lang=en-us --remote-debugging-port=9222 --hung-render-delay-seconds=15 --incognito --proprietary-features=0 --user-data-dir=C:\Users\rhull\AppData\Local\Temp\JxBrowser-UserData-8d816c02-4365-49c2-85af-7fb795744212 --dpi-awareness=per-monitor-aware --disable-fill-background --disable-direct-composition --crash-dump-dir=C:\Users\rhull\AppData\Local\JxBrowser\8.5.0\CrashReports --disable-background-networking --disable-sync --disable-features=OptimizationHintsFetching --disable-component-update --do-not-de-elevate
14:22:49.266 DEBUG Starting chromium process... [OK]
14:22:49.617 DEBUG [Chromium] [0820/142249.616:INFO:compatibility_mode.cc(86)] Actual Windows version: 10.0.26100
14:22:49.617 DEBUG [Chromium] [0820/142249.616:INFO:compatibility_mode.cc(93)] Simulated Windows version: 10.0.26100
14:22:49.617 DEBUG [Chromium] [0820/142249.616:INFO:compatibility_mode.cc(62)] Compatibility environment variable: ElevateCreateProcess
14:22:49.664 DEBUG Accepting connection...
14:22:49.677 DEBUG RPC thread started: id = 107, type = BROWSER
14:22:49.739 DEBUG Accepted: RpcConnection [id = 89557f4a-80d2-4b7d-8436-32a7d972744c; type = BROWSER]
14:22:49.741 DEBUG Product binding call stack:
java.lang.Thread
java.lang.Thread
14:22:49.773 DEBUG [Chromium] [25072:23848:0820/142249.773:WARNING:account_consistency_mode_manager.cc(77)] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
14:22:49.788 DEBUG > [1:70]: rpc.EngineFactory.ApplyLicense [product_name: "JxBrowser" product_version: "8.5.0" stack_trace: ***** key: *****]
14:22:49.811 DEBUG Accepting connection...
14:22:49.812 DEBUG RPC thread started: id = 109, type = NETWORK_SERVICE
14:22:49.813 DEBUG Accepted: RpcConnection [id = cd417cc7-f62d-4972-831d-baab43296109; type = NETWORK_SERVICE]
14:22:49.894 DEBUG [Chromium] [18612:16872:0820/142249.894:WARNING:viz_main_impl.cc(85)] VizNullHypothesis is disabled (not a warning)
14:22:49.894 DEBUG [Chromium] [18612:16872:0820/142249.894:INFO:content_gpu_client.cc(47)] ContentGpuClient::PostCompositorThreadCreated
14:22:49.979 DEBUG Closing RPC thread...
14:22:49.979 DEBUG The connection has been terminated.
14:22:49.980 DEBUG Closing RPC thread... [OK]
14:22:49.981 DEBUG Closing RPC thread...
14:22:49.981 DEBUG Closing RPC thread... [OK]
14:22:49.989 DEBUG Chromium process exit code: -2,147,483,645
14:22:50.013 DEBUG Stopping server...
14:22:50.013 DEBUG Stopping server... [OK]
14:22:50.013 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
 com.teamdev.jxbrowser.engine.EngineOptions:
  autoplayEnabled: false
  chromiumDir: C:\newCache\cache\resources\jxbrowser\8.5.0
  chromiumSwitches: [--do-not-de-elevate]
  diskCacheSize: <unknown>
  fileAccessFromFilesAllowed: false
  isGpuDisabled: false
  isIncognitoEnabled:true
  language:en-us
  passwordStore: <unknown>
  remoteDebugginPort: 9222
  renderingMode: OFF_SCREEN
  isSandboxDisabled: false
  secureOriginWhitelist: []
  isTouchMenuEnabled: false
  userAgent: <unknown user agent value>
  userDataDir:C:\Users\rhull\AppData\Local\Temp\JxBrowser-UserData-8d816c02-4365-49c2-85af-7fb795744212
  webSecurityDisabled: false
com.teamdev.jxbrowser.engine.ChromiumProcessStartupFailureException: Process exit code: -2147483645
	at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:282)
	at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:163)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.lambda$getOrCreateEngine$2(JxBrowserUtil.java:352)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.runResourceLockedAction(JxBrowserUtil.java:558)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:352)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:417)
	at com.inductiveautomation.webbrowser.BrowserInstanceManager.startup(BrowserInstanceManager.java:36)
	at com.inductiveautomation.factorypmi.application.FPMIApp.createApp(FPMIApp.java:336)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.createRoot(VisionDesignerImpl.java:704)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.startup(VisionDesignerImpl.java:364)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:2006)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1202)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:1005)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2050)
14:22:50.016 [Designer-Startup] ERROR WebBrowser -- BrowserEngine was not initialized. Web Browser Component can not start!
14:22:51.494 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+8305]
14:22:52.653 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module.  Mode: Trial
14:22:52.658 DEBUG Acquiring an exclusive lock...
14:22:52.659 DEBUG Checking binaries integrity in
14:22:52.659 DEBUG Using WIN64 listing...
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\libEGL.dll
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-TW.pak.info
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome_200_percent.pak
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\cs.pak
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ar.pak.info
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\th.pak.info
14:22:52.707 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ml.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\af.pak.info
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\resources.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome.dll.sig
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nl.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ca.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\vi.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\uk.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ro.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-US.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sv.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\awt_toolkit64.dll
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bn.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\da.pak
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\MEIPreload\\manifest.json
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\libGLESv2.dll
14:22:52.708 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\toolkit32.dll
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-PT.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\kn.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\MEIPreload\\preloaded_data.pb
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\am.pak.info
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.version
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ms.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ur.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sk.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hr.pak.info
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fi.pak.info
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ar.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\id.pak.info
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es-419.pak.info
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pl.pak
14:22:52.709 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\el.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\he.pak.info
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\mr.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ta.pak.info
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ms.pak.info
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\vulkan-1.dll
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bg.pak.info
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fi.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sr.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fr.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\th.pak
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\tr.pak.info
14:22:52.710 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-US.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\et.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lv.pak
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sv.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\ipc64.dll
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe.sig
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-GB.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\vk_swiftshader_icd.json
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ru.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fr.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ko.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ca.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pl.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fil.pak
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\de.pak
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lt.pak
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ml.pak.info
14:22:52.711 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-TW.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\it.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fa.pak.info
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome.dll
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\am.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\awt_toolkit32.dll
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sl.pak.info
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hu.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sr.pak.info
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ta.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\el.pak.info
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\en-GB.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\ipc32.dll
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hi.pak.info
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nb.pak
14:22:52.712 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sw.pak
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\te.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\cs.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ko.pak
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\vi.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\gu.pak
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\toolkit64.dll
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\uk.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-PT.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\d3dcompiler_47.dll
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es-419.pak
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ja.pak
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\it.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\134.0.6998.89.manifest
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\da.pak.info
14:22:52.713 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\gu.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\te.pak
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\he.pak
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bn.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\pt-BR.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome_elf.dll
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ur.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-CN.pak
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\de.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fil.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\bg.pak
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\es.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\et.pak
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sw.pak.info
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\vk_swiftshader.dll
14:22:52.714 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nl.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\fa.pak
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lt.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\af.pak
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hi.pak
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\chrome_100_percent.pak
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\nb.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\icudtl.dat
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\mr.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\v8_context_snapshot.bin
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\tr.pak
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ja.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hr.pak
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\lv.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\hu.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\sk.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\kn.pak.info
14:22:52.715 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ro.pak.info
14:22:52.716 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\zh-CN.pak.info
14:22:52.716 DEBUG Checked C:\newCache\cache\resources\jxbrowser\8.5.0\locales\\ru.pak
14:22:52.718 DEBUG Checking binaries integrity... [OK]
14:22:52.719 DEBUG Releasing the exclusive lock...
14:22:52.719 DEBUG Starting server...
14:22:52.719 DEBUG Starting server at port 55703... [OK]
14:22:52.720 DEBUG Accepting connections...
14:22:52.721 DEBUG Starting chromium process...
14:22:52.721 DEBUG __COMPAT_LAYER variable detected: ElevateCreateProcess
14:22:52.722 DEBUG C:\newCache\cache\resources\jxbrowser\8.5.0\chromium.exe --port=55703 --pid=26848 --browsercore --no-default-browser-check --off-screen --lang=en-us --remote-debugging-port=9222 --hung-render-delay-seconds=15 --incognito --proprietary-features=0 --user-data-dir=C:\Users\rhull\AppData\Local\Temp\JxBrowser-UserData-0158fdf7-c607-4ba2-8742-9d5e3ee0099c --dpi-awareness=per-monitor-aware --disable-fill-background --disable-direct-composition --crash-dump-dir=C:\Users\rhull\AppData\Local\JxBrowser\8.5.0\CrashReports --disable-background-networking --disable-sync --disable-features=OptimizationHintsFetching --disable-component-update --do-not-de-elevate
14:22:52.726 DEBUG Starting chromium process... [OK]
14:22:52.816 DEBUG [Chromium] [0820/142252.816:INFO:compatibility_mode.cc(86)] Actual Windows version: 10.0.26100
14:22:52.817 DEBUG [Chromium] [0820/142252.816:INFO:compatibility_mode.cc(93)] Simulated Windows version: 10.0.26100
14:22:52.817 DEBUG [Chromium] [0820/142252.816:INFO:compatibility_mode.cc(62)] Compatibility environment variable: ElevateCreateProcess
14:22:52.863 DEBUG Accepting connection...
14:22:52.864 DEBUG RPC thread started: id = 123, type = BROWSER
14:22:52.864 DEBUG Product binding call stack:
java.lang.Thread
com.inductiveautomation.perspective.designer.DesignerHook
java.lang.Thread
14:22:52.864 DEBUG Accepted: RpcConnection [id = a642272d-8d28-47f8-9170-612bc1798c16; type = BROWSER]
14:22:52.865 DEBUG > [2:70]: rpc.EngineFactory.ApplyLicense [product_name: "JxBrowser" product_version: "8.5.0" stack_trace: ***** key: *****]
14:22:52.896 DEBUG [Chromium] [28804:3140:0820/142252.896:WARNING:account_consistency_mode_manager.cc(77)] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
14:22:52.933 DEBUG Accepting connection...
14:22:52.934 DEBUG RPC thread started: id = 126, type = NETWORK_SERVICE
14:22:52.934 DEBUG Accepted: RpcConnection [id = 846ce30b-c5a9-4413-85c4-58c844d1b1c7; type = NETWORK_SERVICE]
14:22:53.015 DEBUG [Chromium] [28284:2056:0820/142253.014:WARNING:viz_main_impl.cc(85)] VizNullHypothesis is disabled (not a warning)
14:22:53.015 DEBUG [Chromium] [28284:2056:0820/142253.015:INFO:content_gpu_client.cc(47)] ContentGpuClient::PostCompositorThreadCreated
14:22:53.096 DEBUG Closing RPC thread...
14:22:53.096 DEBUG The connection has been terminated.
14:22:53.096 DEBUG Closing RPC thread... [OK]
14:22:53.098 DEBUG Closing RPC thread...
14:22:53.098 DEBUG Closing RPC thread... [OK]
14:22:53.106 DEBUG Chromium process exit code: -2,147,483,645
14:22:53.128 DEBUG Stopping server...
14:22:53.128 DEBUG Stopping server... [OK]
14:22:53.129 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
  language:en-us
  userDataDir:C:\Users\rhull\AppData\Local\Temp\JxBrowser-UserData-0158fdf7-c607-4ba2-8742-9d5e3ee0099c
	at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:233)
14:22:53.187 [Designer-Startup] INFO designer.main -- Starting module: SFC [+9999]
14:22:53.640 [Designer-Startup] INFO designer.main -- Starting module: Event Streams [+10452]
14:22:53.709 [Designer-Startup] INFO designer.main -- Starting module: OpcCom [+10521]
14:22:53.710 [Designer-Startup] INFO designer.main -- Starting module: Reporting [+10522]
14:22:53.756 [Designer-Startup] INFO reporting.Designer -- Starting up Reporting Module. Mode: Trial
14:22:53.932 [Designer-Startup] INFO designer.main -- Starting module: Symbol Factory [+10744]
14:22:53.934 [Designer-Startup] INFO designer.main -- Starting module: Alarm Notification [+10746]
14:22:54.041 [Designer-Startup] INFO designer.main -- Starting module: OPC-UA [+10853]
14:22:54.042 [Designer-Startup] INFO designer.main -- Starting module: Enterprise Administration [+10854]
14:22:54.060 [Designer-Startup] INFO designer.main -- Starting module: Legacy DNP3 Driver [+10872]
14:22:54.060 [Designer-Startup] INFO designer.main -- Starting module: Historian Core [+10872]
14:22:54.060 [Designer-Startup] INFO designer.main -- Starting module: SQL Bridge [+10872]
14:22:54.266 [Designer-Startup] INFO designer.main -- Starting module: Kafka Connector [+11078]
14:22:54.271 [Designer-Startup] INFO designer.main -- Starting module: WebDev [+11083]
14:22:54.290 [Designer-Startup] INFO designer.main -- Initializing Scripting... [+11102]
14:22:54.394 [Designer-Startup] INFO designer.main -- Initializing UI... [+11206]
14:22:54.404 [Designer-Startup] INFO com.inductiveautomation.ignition.designer.querybrowser.QueryBrowser -- No default datasource set for project. Set default in gateway and relaunch project.
I got some news. It does seem to be the AV we got another computer here that does not have it installed and perspective showed up like normal. So there must be something blocking it, though I don’t know what.
