Perspective Numeric Entry (Button Style)
Hello All,
Using a numeric entry set to Button style which gives you a pencil icon next to the field to click and enter a value. My question is on formatting the popup that opens to show a decimal format. Is this possible? Also, I would like to control the amount that the up and down arrows adjust the value, it seems the default value is 1.0. Any help or information is appreciated.
Thanks,
Frank
What pencil icon?
If there is no prop for this then im afraid its not possible, it would require javascript.
edit: ah seems there is a prop for it
spinner.increment
nvm it doesnt work for the button mode
if none provided an answer by monday give me a ping and ill take an other look. gtg now
So the spinner.increment does work on the popup too, but you have to have a value in it (value is not empty but is zero)
For styling you can change the theme.css (or use injection)
for the buttons
.ia_numericEntryFieldComponent__modal_content > .ia_numericEntryFieldComponent__modal_buttons > button {}
for the pencils (note its an svg)
.ia_numericEntryFieldComponent__editIcon{}
and
.ia_numericEntryFieldComponent__editIcon--active{}
Hi @victordcq,
Have you been able to do the same thing for the Oneshotbutton?
I tried to replicate these steps for it but I think it requires setting the style for
.ia_button--primary which is not desirable.
Idk what you are looking to chance, i can just change the colors with the props
ah maybe these?
something like this should be specific enough
div:has(.ia_oneShotButtonComponent__confirmModal__message) [data-button-type="confirm"] { background-color:green}
div:has(.ia_oneShotButtonComponent__confirmModal__message) [data-button-type="cancel"] { background-color:red}
