I’ve successfully implemented passing parameters to the main view by creating a new page with the parameters specified in the URL per here.
I have two parameters that I am passing.
- In a new tab, when the user only specifies one parameter, the page loads up with that parameter and the other as empty string (as expected).
- Within the same tab, if the user tacks on the 2nd parameter, the page loads up with both parameters (expected)
- In the same tab, if the user removes the 2nd parameter, the page loads up with both parameters (unexpected; I was expecting the 2nd parameter to be an empty string).
Every time the URL is modified and executed, I’m seeing the following splash screen, so I would have expected everything to be coming up clean without old data:
