Perspective: Passing in an object structure/json into page url param
Is it possible to pass in an object/json structure into a page url param? E.g. say I had this object property:
Can I pass in rowData into the url param?
Note: I’m not saying I have a use-case for this at the moment, but just wondering in case i find one.
Unfortunately it’s not possible without some effort
All perspective sees in your URL is one big long string parameter, however you can use url encoding in a string parameter and reverse engineer it into a dictionary with a transform.
I.e.
/param1=123&param2=abc&param3=41v could be split into an array based off of the ampersand, and then broken apart into keys from there.
This is how I do it currently, unfortunately, I just keep a function in my inheritable project to cover this in any projects I need it for
