Perspective Performance - View Bindings vs Expression Tags
I am using CSS-based styles for shading graphical components on Perspective Views for device UDT's based on their status (like Running or Failed). In regards to performance, I have found that bindings on Views can create overhead (especially in more complex views). So, I am considering using expression tags instead when able to help reduce the processing load in the Views, putting it into the Gateway instead. Is this a viable path to follow?
Example case of this:
  1. Component on View has an expression binding to its styles.classes prop that references multiple parts of a UDT instance.
  2. Instead of this, I would create an expression tag in the UDT that does that evaluation instead and bind that to the style.classes prop of the aforementioned component (i.e. Device.GraphicStyle)
Thanks!
Everything in Perspective runs in the gateway. There's no "instead". If you have many UDT instances (more than Perspective clients that would execute that expression in a view), you might increase the total workload in the gateway, because those expression tags would execute even when no client was using them.
Interesting, so the client programs basically show the results of this processing? Does this mean that the performance of a client program is more dependent on both the speed of the connection to the gateway and the gateway's processing power and much less on its own processing power?
Yes, Perspective places significant load on the gateway--all customization of appearance and behavior runs in the gateway.
Your original surmise would be correct for Vision, not Perspective. Perhaps you should read this topic (and the links within):
