I am opening popup in Ignition Perspective and resize it as per requirement.
I want read popup height and width after resizing same online.
Its not really possible.
Why do you need to know it?
i am working on some application which require dimension of component that component basically replica of physical object in the form of popup so i would need width and height of popup after resizing it
There are a lot of complexities here. You have have to know every device, their resolution and even then it may not be enough. There would have to be some intense info gathering and scaling to make that work. it would def be an uphill task
try the dashboard component, you’ll have more luck with that to let the client position something
https://docs.inductiveautomation.com/display/DOC81/Perspective+-+Dashboard
