If I open a popup window (A) that has a button that closes the current pop up and opens another (B)I am seeing the following behavior.
If I drag A somewhere other than center then click button to close A and open B, B opens but it is skewed to be centered wherever I moved A which causes it to be partially visible. How do I allow A to be dragged but B to always open centered on screen independent of position of A?
Thanks,
Frank
I have found that if I specify a Top and Left position in the popup open config this corrects this behavior.
I would need to see the configured Event or script to help clarify the behavior you were seeing. I would also need to know what version you’re using.
When I tried this out locally I did not see the behavior you described.
- If I click Button0 then I see PopupA.
- I then drag PopupA in some direction and click the Button present in PopupA.
Result:
PopupA is no longer present, and PopupB has opened in the center of the Page.
Just assign an unique id each time it opens, I usually use a datetime to give this effect of “additional instance”.
