I’m on 8.0.16
I search a way to reset temp values iof a vuew thjat is used in a popup.
The reset can be done on open or close of the popup. If possible I don’t want to pass throw parameters because I a have a lot of temp values that I want to reset…
I’m on 8.0.16
Consider using expression bindings that hold the constant you want to start with. Such bindings only fire on window open.
