Perspective Power Chart caches the range brush area
Ignition 8.3.9 Perspective
I add a pen to the chart in X Trace mode. I switch to range brush and create a range . then I try to load a saved trend into the chart. Before I load the saved trend, I change the chart mode to Xtrace and clear the range brush data .
however the trend itself seems to be caching the range area somehow. If I reload the page the range is gone .
Is this is a known issue? or am I missing something
Try clearing from the more menu nearby the chart selection option buttons. Same behavior?
User can save trends .
Initially I got component error when I tried to save range brush data and load it from my list.
So now I am not saving the range brush related data before saving and loading .
I clear any range brush related data on the chart , switch the mode to xTrace and load the new trend.(in the scirpt)
So 1. the clear range brush option is not available in xTrace mode and 2.the range is not there , it is some sort of ghost range , since the print shows the data is empty and refreshing the page takes away the ghost range.
Moreover, I do it in the script. so is there any method that corresponds to clear range option?
