Perspective - Power Chart - Customizing layout
Trying to figure out how to customize the Power Charts in a build to match the colors, layout, logo/watermark as the rest of the app. Ignition 8.0+ Perspective
It doesn’t seem like these features really exist? Is there a way to do this by adding some kind of custom syling / plugin? Or by adding more into the props > config section? Thanks-
-Hannah
Corso Systems
If the styling for any component doesn’t have a place in the Designer gui, you can always try changing it in the CSS within your custom theme. Check the component’s CSS already within the light theme’s ‘palette’ directory and simply copy and paste the component you want to change the styling for into one of your theme’s CSS files.
C:\Program Files\Inductive Automation\Ignition\data\modules\com.inductiveautomation.perspective\themes\light\palette
Note: CSS you write in here that has styling fields for in the Designer gui won’t be applied, as the gui has precedence.
I thought it had to be something like that. Going to give that a shot. Thanks!
