Perspective Power Chart - Disable tag path edit on Pen Control Edit
Hi there,
Is there any way we can disable tag path edit for the end users on Pen Control Edit (Perspective Power Chart)?
If we have an option to hide the tag path would be great as well.
Thank you
I've been asking for the same thing.
Me too… For the exact same reason.
Contacted support about this a few months ago, but no solution could be found, except for hiding every configuration panel, which is not ideal.
Currently the best you can get is to hide it via CSS.
Thanks, that’s a first step.
Is this still true?
As far as I know
thanks, operators cannot be trusted with edit and delete!
