Perspective Power chart - problem displaying values in table below
I'm trying to put float values whit two decimal placeses from expression tags into the power chart. Problem is with displayed values in the table below. In the designer everything looks ok, but when i run Perspective session values look like in long format. What am I doing wrong?
I’ve the same problem. On the designer, the format IS correctly shown. In an Explorer session not.
Any ideas about It?
Same problem here in 8.1.3
It seems that the problem persists in 8.1.7, any updates?
I can confirm the same behavior on Ignition/Linux 8.1.7 (b2021060314), I’ve used values from the “Programmable Device Simulator”. This seems to happen with the float / double values, not the integer / long ones.
Changing the format string in the tag browser, does not seems to have any effect.
Hi I’m having the same issue, any news in this regard?
Thanks!
I resume this topic because I’m having the same problem with Iginition 8.1.7
In preview mode everything is perfect, withe browser numbers look crazy.
Hello same problem, Does Anyone have any update or possible fix ?
I change the regional configuration of my explorer in my case Chrome and works well
