Perspective power chart
I have a power chart with historical data (tags) and I would like to add a static plot, eg. a target or threshold to the chart.
How should I add this value to the chart?
Within the Chart Settings, under Plots, you can edit a plot to add a marker.
Editing the respective plot will bring up this screen, where you can click “Add Marker”
Clicking “Add Marker” will allow you to plot a static target/threshold on to the respective plot you are editing.
You can select between a “band” type and a “line” type, specify the marker color, width, dash spacing, opacity, etc. You can even add a label.
If you are planning on having this dynamically generated, you can look at the component properties to copy the structure and try your hand at auto-generating that structure and assigning to a PowerChart component.
Hope this helps.
