Perspective Power table
Hi I want to make a header group to the power table at perspective.
For example the table on the file attached. On the sample you can see sales/margin/quantity over the table header.
Is it possible? How to nest lower headers under the top header?
Regards,
Leandro
Perspective doesn't have a Power Table component - only a Table component.
As far as I remember you can't merge cells on the Table component - whatever about in the header.
There is a feature called "Header Groups" on the Perspective table and it's designed for this scenario exactly. I'm too dumb to figure out how the span property works and the docs don't talk about it, but I believe that's the feature you want.
Thank you very much! It’s very helpful
