Perspective Powerchart Aggregation Mode
Is there a way to get the perspective powerchart to draw ‘on change’ datapoints correctly? I frequently have tag values that are constant for a long period, then suddenly change value. I can get the correct behavior in vision if I pick a raw or natural aggregation mode and Digital line type.
Example of the powerchart incorrectly simply connecting the dots:
Proper behavior, it assumes the value doesn’t change until it sees a new value.
It has been a while but I was just wondering if you were able to fix this issue as I am having the same problem
Hi Jasmin, try setting the tag history's Deadband Style to "Discrete" and then, in the Chart Settings, Edit Pens Display Interpolation to "CurveStepAfter". Good luck
Yes I implemented that yesterday and it is working like I want now. Thank you for your help though!
