Perspective: PowerChart Component - Config - Hidden Properties or Missing Properties ( 8.1.0 )
Not sure if there is a trick to accessing all the properties of a Perspective Component (PowerChart) but the Designer shows the following properties:
However the manual lists the following:
Is it possible to access the other properties or is this a version discrepancy and the manual is just a little out of date with software version?
Properties can be hidden based on other properties - try switching the mode of the chart.
You are too smart…:slight_smile: That is exactly what reveals the properties. Thanks again!
