Perspective Project Startup
Hello hivemind of Ignition users,
A question most likely to need a developer to weigh in on. What are the statuses and associated activities going on when a perspective project starts on a browser?
For instance I see Synchronization, Loading resources and perhaps there are more? What happens in each of those steps specifically? Is there an article in the manual that maybe I missed? Is there some other document I can look at?
The issue is actually that I have a client whose project seems to hang on Synchronization for over a minute during startup. And oddly it's not all the users from that company, just a couple. They see the issue while in the office on strong wifi connections and while out in the field over cellular data (although I don't know how fast/how much bandwidth they actually have).
Completely undocumented implementation details. (Not likely to ever be documented.) Though you should be able to use your browser's developer tools to watch what is going on (try the network tab).
If you can't figure it out, you should ask IA support to look over your shoulder.
