Perspective Properties - Value error
I got this caution while binding a query to this property. As I binded the expected datatype "Integer". But it is showing the expected error "string found" . how to resolve this
Show us your binding. (If it's an expression then please post </> formatted code rather than a picture of code.)
Its a Query Binding
Select Top 1   PF from  Main WHERE  BG =:bg and Plant =:pl and Line=:ll  and Machine =:ma and
Date between :st and :sp
order by Date desc
    "type": "ia.chart.simple-gauge",
    "version": 0,
    "props": {
      "minValue": -2,
      "maxValue": 1,
      "startAngle": 0,
      "arc": {
        "color": "#008000"
      "arcBackground": {
        "color": "#008000"
      "label": {
        "visible": false
      "animate": true,
      "style": {
        "classes": []
    "meta": {
      "name": "SimpleGauge"
    "position": {
      "basis": "300px"
    "custom": {},
    "propConfig": {
      "props.value": {
        "binding": {
          "type": "query",
          "config": {
            "returnFormat": "scalar",
            "queryPath": "Online_PF",
            "parameters": {
              "ll": "{..../Line_Dropdown.props.value}",
              "st": "{..../DateTimeInput.props.value}",
              "ma": "{..../Machine_Dropdown.props.value}",
              "bg": "{view.params.BG}",
              "pl": "{view.params.Plant}",
              "sp": "dateArithmetic({..../DateTimeInput.props.value}, 1, \"days\")"
What data type is the database field PF? If it's a string or text then that's probably your problem.
I can reproduce the error by creating an expression binding with the simple expression "-0.99" which, of course, is a string.
If you can't fix the DB then try adding an expression transform on the binding.
toFloat({value})
Thanks for the suggestions.I have added the Expression transform. Now it works well.
Or change the query, which would be a touch more performant:
SELECT Top 1 CAST(PF as float)
FROM  Main
WHERE  BG =:bg
   AND Plant =:pl
   AND Line=:ll
   AND Machine =:ma
   AND Date BETWEEN :st AND :sp
ORDER BY Date DESC
