Perspective Property binding and scripting parse error
Hi, I’m having trouble with my scripting to change the background color of some components.
I am a beginner at python so any advice would be greatly appreciated!
My goal is to turn the background color of each of the Red/Yel/Grn components 1 of 2 colors.
If the custom property “Light_On” is true,then turn the background color to “Light_Color_On” (#0000FF)
If the custom property “Light_On” is false,then turn the background color to “Light_Color_Off” (#0000FF80)
Currently, I have tried the following script after a Property binding, but I keep getting an error:
                   Error_Configuration("Parse Error in script transformation")
	newcolor = self.custom.Light_Color_On    #  "#FFFF00"
	oldcolor = self.custom.Light_Color_Off   #  "#FFFF0080"
	if value:
		returncolor = newcolor
	else
		returncolor = oldcolor
	return returncolor
Not sure what my error is or how to fix it.
Please and thank you!
You are missing the colon after you else.
If value:
    #do something
else:
    #do something else
Thank you! As I said, I am very beginner level.
No problem, though the more Pythonic way to write this script would be:
if value:
    return self.custom.Light_Color_On
return self.custom.Light_Color_Off
The better way to do this in Ignition would be to use an expression binding with this expression:
if(self.custom.Light_On,self.custom.Light_Color_On, self.custom.Light_Color_Off)
Better yet would be to use CSS theme variables so that you don’t have hard coded “magic” colors.
