Hello, i trying to edit some properties of components, but the panel perspective property editor is missing. I’ve tried to reset the panels and to enable the property editor panel, but it doesn’t show up. There’s a topic on the forum which the problem was solved by deleting the perspective-workspace.layout file on .ignition folder, but there’s no such file on my folder and there’s no hidden file.
Ignition Designer
.ignition folder
The Perspective Property Editor is context-specific, meaning it’s only visible when you’re in the Perspective context. Since you are currently in the Vision context, it only makes sense to display the Vision-specific panels. In the Project Browser, if you click “Perspective”, you should see the Vision Property Editor removed, and the Perspective Property Editor should replace it.
Oh, i can’t believe it was just this. Thank you very much.
