Perspective Property's Bad_NotFound Error
I'm getting Bad_NotFound error message when trying to get some property of Perspective (like username). I attached a screenshot about that. I'm using Ignition Edge trial in my demo and visualization is choosen by Perspective in gateway settings. Do you have any idea why it's happening?
Thanks!
Does it actually exist in the Perspective Session Props and does it have a value when inspected in Designer? (I've never used Edge.)
Yes, property is exist in Perspective Session Props. I also tried re-install ignition 8.1.33 with different version (Ignition and Ignition Edge installed several times for tryin). Same thing is happening in my local pc installation but i installed same pc to Ignition on Docker Desktop, working without any Bad_NotFound issue in a strange way :slight_smile: Is there any missing requirements for installing Ignition, i don't know
Sorry, I was unable to reproduce the fault.
That's interesting. What information is available when you hover over the red text, or the red warning triangle in the Property Editor?
Here is the information when i hover over the text in the Property Editor.
