I have a report created in Perspective (v8.1.44) Reporting Module (v6.1.44). Within my report, I have a table component. This data in the tables' cells are populated thru a SQL Query. For the cells of the table, I want to be able to change the font weight (between Normal and Bold) based on a condition I have. I have this script working and this is all great. My problem is when I try to apply the Bold format to one of the cells. For example, the cell "Project Name". The value displayed in this cell should be Bold, based on the current condition. So, in the report Previewer, the cell appears in the Bold state correctly. But, when the report is generated, into a PDF, the Bold format of the cell is not working. To troubleshoot this, I decided to first manually set the cell font to "Tahoma, Bold, 11" to see what would happen. I received the same results, Report Previewer displays the cells' font in Bold but the generated PDF is not displaying the cells' font in Bold it is "Plain". What am I doing wrong? This seems like such a simple thing to do...
Thank you
