Perspective scripting-how to reference a specific cell in a table in python
Help please, I have been stuck for the last 2 hours.
Overview of what i am trying to do:
I have this table in Perspective- it is pulling from a SQL database
I am trying to configure a button to use a for loop to go though each row of this table.
on each row the loop would grab the SheetID cell value and then use that as a parameter to run a query. (it has to be done in python).
Here is the issue i am running into and I desperately need help on. How do I reference a specific cell value in this table???
the loop is simple
R=0
While R< num rows
  • grab sheet ID value (I can not do this)<------------(this is where i need help)!!!
  • run query pass sheet id as parameter ( i can do this)
  • R +=1
All I need is to know how to reference a specific cell (When it is NOT selected). If you can help thank you!!
Past Tries: This is where i am coming from (I do not need help on anything below this, i am just giving you background of where i am stuck)
I have tried using Event configuration on a label to get the label to display the cell value
##table = event.source.parent.getComponent("Table")
##value = table.data.getValueAt(0, "SheetID")
##self.props.text = value
Are you using a dataset or JSON for the table's data property?
This works with the default table component data.
def runAction(self, event):
	data = self.getSibling("Table").props.data
	for row in data:
		country = row['country']
		# Do something with country ...
Please see Wiki - how to post code on this forum.
Data set, the table is a dataset from a sql query
In the SQL Query binding window, set it to output JSON as the output format.
Then you can easily use python to iterate through the table.
That worked, thank you
What's the query that needs to be done for each row ?
For posterities sake, you don't have to use the JSON return format to accomplish this.
    data = system.dataset.toPyDataSet(self.getSibling("Table").props.data)
    for row in data:
         sheetID = row['SheetID']
         specificData = system.db.runNamedQuery('YourNamedQuery',{'SheetID':sheetID})
Or, if you don't want to use a PyDataSet it would look like this:
    for row in range(data.rowCount):
        sheetId = data.getValueAt(row,'SheetID')
Thank you, that will be helpful in the future
I already solved it but the query is to find all sheets with that SheetID and change an assigned bit value from 1 to 0 or 0 to 1.
If I understand correctly, I think you should be able to do it in one query with something like this:
ids = data.getColumnAsList(data.getColumnIndex('SheetId'))
q = """
update your_table
set column = ~column
where SheetId in ({})
""".format(','.join("?" for _ in ids))
system.db.runPrepUpdate(q, ids)
