I am trying to make a label visible on a screen. The View has a parameter of "Contactor_Num" which is an integer. The PLC has a tag (CUR_ACT) with an integer. If they are the same, make the label visible. In the designer this works absolutely perfectly. If view parameter is set to 2 and PLC tag is 2, it shows up. If I change the PLC tag to anything else, it disappears. After I save the project and launch a session, the label will NEVER show up, no matter what I make the numbers. I have never seen this before and was wondering if anyone else has.
Any thoughts greatly appreciated.
- Are you sure you saved the project?
- Are you sure you are looking at the correct view in the client?
Showing how you set things up will help us troubleshoot as well.
Please attach some pictures to help us troubleshoot.
