I'm struggling to animate a pump in Perspective environment, via Props > state >running, stop, etc.., while I can do that in Vision, I cannot do it in Perspective, I'm using few Boolean values from Plc to show the pump is running, stopping, fault, etc.
please can anyone help, I just recently started using Ignition.
You need to create a binding on the pump's props.state property. There's a dropdown there that shows you the valid options are default, running, stopped, faulted.
