Perspective - Sparkline
When using the sparkline chart in perspective. I do not see any way to set high/low range, or high/low desired. The description of the perspective component from the manual describes the importance of setting desired ranges as there is no labeled axis. I do not see any way to set up this.
just found this post talking about the same issue. So it must already be known.
