Perspective Styles Dynamic CSS Props/Variables
If I have a style class like this in the stylesheet:
.psc-flow-arrow-down {
  animation: flow-arrow-down-animation 1s infinite;
@keyframes flow-arrow-down-animation {
  0% {
    transform: translateY(0px);
    opacity: 0;
  40% {
    opacity: 1;
  100% {
    transform: translateY(75px);
    opacity: 0;
Are there any options for using this class on a component and dynamically changing props like the translateY?
Dynamic in what way? Like changing the 75px to, say, 85px? In CSS, you can create a variable and then use it in the translateX/Y function, but I'm not sure how you'll write to it from the session.
What you could do, depending on how many different options you have to translateX/Y, is to just define the style class based on the different translate amounts... This is obviously suboptimal, but the first that came to mind, say, if you had 5 - 10 different options.
Something like
.psc-flow-arrow-down-1 {
  animation: flow-arrow-down-animation-1 1s infinite;
@keyframes flow-arrow-down-animation-1 {
  0% {
    opacity: 0;
  40% {
    opacity: 1;
  100% {
    opacity: 0;
.psc-flow-arrow-down-2 {
  animation: flow-arrow-down-animation-2 1s infinite;
@keyframes flow-arrow-down-animation-2 {
  0% {
    opacity: 0;
  40% {
    opacity: 1;
  100% {
    transform: translateY(105px);
    opacity: 0;
This feels almost wrong to do this, but I don't know how else you can dictate the animation from the session without having to do a write to the filesystem to update the CSS variable or something complicated like that. It would be easier to do in native development.
[I'm operating under the assumption that you'll want to be able to dictate the animation from the session]
You can create the animation properties directly on the object and use bindings to manipulate it.
Otherwise I don’t know of any way (outside of JS) to manipulate the styles dynamically, at runtime.
How do you mimic keyframes with component props though? Maybe I'm overthinking this, but didn't know how to do that.
You don't, but here what you could do:
define your variable in classes. Something like:
.psc-size1 {
	--size: 75px;
.psc-size2 {
	--size: 85px;
.psc-size3 {
	--size: 95px;
then use this variable in your animation:
.psc-some_class {
	animation: some_anim 1s infinite;
@keyframes some_anim {
	to {
		transform: translateY(var(--size));
now you can give the sizeX class you want to your component, along with the animation class.
This is the way, aslong you are not going to abuse it and change the classes every second on the fly on the same component
Well, I guess I wasn't exactly clear, as I made an assumption that this is for an SVG.
If that is the case then you can do this in the props with an embedded SVG:
flowarrow
If it isn't an SVG, then @pascal.fragnoud's approach is what I would use.
Depending on the need you could also use percentages and just put it on a wrapper container or something that you can resize to whatever size you want (be it 75px or 100 px or whatever)
You might have to handle overflow too tho
  0% {
    transform: translateY(0%);
    opacity: 0;
  40% {
    opacity: 1;
  100% {
    transform: translateY(100%);
    opacity: 0;
