[Perspective] Table Cell Editable
Hello. Is there a way to make the cell of a column editable, while leaving all the other cells in the same column non-editable?
I’m already aware that we can set up the dataset with a style attribute (e.g.: to customise the background colour of a single cell). What I’ve done in this picture doesn’t seem to work.
Thank you!
You would need to render the column as a View and use control the enabled/disabled state of the input via params passed in from the Table/data.
So I can achieve that by using the viewPath and viewParams objects, right?
Thank you!
Out of curiosity, have you tried moving that editable property outside of the style object, but still within the cell object? I don’t know if that would solve your problem, but I would not expect the editable property to live inside the style properties.
@swolnisty, looks like it works! Thank you so much.
