I have a perspective table with a date column that I would like to render as a view. If I enable the column filter, it uses a number data type instead of date.
If I select "date" or "auto" (without specifying a viewPath) as the render type, the column filter works fine. All other data types work fine when rendering as view.
Example when column is rendered as date:
Example when column is rendered as view:
Table data:
I have tried both dataset and JSON for the table data with the same results.
The column's view in this example is just a simple label that displays the value parameter passed in from the table data. My actual use case is more complex, but I wanted a simple example to show this potential bug.
I think this is a bug because it conflicts with what @ynejati says in this post:
https://forum.inductiveautomation.com/t/feature-13927-perspective-table-filter-by-column/24753/20
I am using Ignition version 8.1.44.
