Perspective Table Column Width Auto change when filtered multiple times
Ignition version: 8.1.16
Hello I am facing weird problem with Perspective Table component.
I have large dynamic data (around 2000) rows displayed on table and provided some filters on top. In the table component last column is set no width and Strict-Width is set to False. There are 2 such columns in table with no width and Strict-Width is set to False.
Now when in Session, I look at data and apply some filters on it multiple times, the last column width gets lesser for each filter and later it goes out off table.
Also if I switch between views and visit again the same view, the width comes back as normal. Again while applying filter it continues.
What is causing this and it should be known issue. Please advice.
