Perspective - Table Columns with Sub Keys
Utilizing Perspective, let's say I have data in the following form (an array of dictionaries with sub-dictionaries):
"value1": "value",
"sub_dict": {
"value2": "value",
"value3": "value"
"value1": "value",
"sub_dict": {
"value2": "value",
"value3": "value"
I want to display this in a table such that I have columns for "value1", "value2", and "value3". I can get "value1" to show up as a column in the table but I'm having troubles getting the keys in the "sub_dict" to show up as columns in the table (see attached picture sample). Is there some special syntax? Is this even possible? Note, I can get "sub_dict" to show up as a column, but I really want the keys within that dictionary, not the entire dictionary.
sample_table_column
No, you can't really do this. You could give sub_dict a custom renderer view that 'fakes' having multiple columns (not super well), but there's no way to get the table to do this without flattening your data at the source.
You could convert it to a list suitable for the table data using a script. Try pasting this into the Designer Script Console.
myData = [
		"value1": "valueA1",
		"sub_dict": {
			"value2": "valueA2",
			"value3": "valueA3"
		"value1": "valueB1",
		"sub_dict": {
			"value2": "valueB2",
			"value3": "valueB3"
def convertToList(data):
	output = []
	for datum in data:
		value1 = datum['value1']
		value2 = datum['sub_dict']['value2']
		value3 = datum['sub_dict']['value3']
		output.append([value1, value2, value3])
	return output
convertToList(myData)
@Transistor, yes, thank you for the idea. I think I'm going to have to do something very similar to what you proposed.
You're welcome.
Tip: when posting code ...
You could unwrap one layer with this expression:
forEach(
	{path.to.source.data},
	asMap(
		asPairs(
			asMap('value1', it()['value1']),
			it()['sub_dict')
Yes, but who would understand it? Not me!
