I am confused.
Gateway System Time is: 17 hour (UTC)
Project timezone is:
The Dataset value is (UTC):
But Table display is offset (UTC + 5)?
Why Table display offset time??
I don't know, but since you're not getting any answers here can you post the JSON for the date column properties or even a screengrab of the configuration?
Double check that the session timezone ID hasn't been overwritten.
Thanks for keeping tab.
I have this on my project script:
The dataset tag have two columns (date and log):
def create_tag():
## create dsErrorLog tag
parentPath = "[default]Settings"
tagName = "dsErrorLog"
tagPath = parentPath + "/" + tagName
if not system.tag.exists(tagPath):
#create tag
tag={}
tag['name'] = tagName
tag['tagType'] = 'AtomicTag'
tag['valueSource'] = 'memory'
tag['dataType'] = 'DataSet'
tag['value'] = system.dataset.toDataSet(["date","log"], [])
system.tag.configure(parentPath, [tag], collisionPolicy="o")
def error_logger(newMsg):
tagPath="[default]Settings/dsErrorLog"
ds = system.tag.readBlocking(tagPath)[0].value
newDs = system.dataset.addRow(ds, [system.date.now(), newMsg])
system.tag.writeBlocking([tagPath], [newDs])
return None
The gateway timezone is UTC.
Seems that, the perspective table component is wrongly assumed the timezone of the date column on the dataset tag.
One work-around I found, cast to string str(system.date.now()) so that it will specify timezone as well.
