I have a dataset with date/time columns containing UTC date/time values.
When I display them in a Perspective table component, if I set ‘render=auto’, it will apply a local time offset and render them as local times.
If I set ‘render=date’, it does NOT apply the local time offset, and instead displays them as their original UTC times.
I’m fine with this, I just want to know if this is the intended way the component is meant to work, or if it’s a bug that might be fixed at later time, or if I’m possibly doing something wrong. I couldn’t really find any clarification in the documentation.
I’m curious as well. I’m not super familiar with Perspective. My guess would be its normal. render=date just shows it as that /o any extra work. And the render=auto must do conversion. But this is something they could probably correct in a future version. but again this is just to add to the thread, take everything with a grain of salt. Hopefully a more experienced user or someone from IA can add/clarify
@ShaneH
Yes that is what the intended way the table component is meant to work and not a bug.
Because while using table component in perspective 8.1.0 I am facing serious issue as this feature is not there and its a bug here in this version.
Setting up render auto is adding offset & showing local time.
Setting up render to Date is still adding offset & showing local time instead of showing UTC time.
let me explain more with the example.
my dB & Ignition Gateway both set to UTC while I am launching client from IST(+5.5)
I am getting this offset With respect to the local time zone.
This may vary and will show incorrect data if you access view from different zones.
Umeshchandra Adamanke.
