There’s an onSubviewExpand Table event handler that you can use to detect which row was expanded, and then force a selection on that row.
Thanks, just added
self.props.selection.selectedRow=event.rowIndex
to configure event for subview, but should not be necessary to add extra code for the table to update
In case you would not like to do this.. if you make an parameter on the subview with an object type like this:
value = {
columnName : value
it will automatically pass it through without any extra bindings or scripting
