Perspective Table - dynamic column width and hiding rows
Are the column widths in a Perspective table limited to using pixels as the units, or is there some way to use a percentage of the table width. I’d like the column widths to be as dynamic as the rest of the element sizing on the view, but I don’t see any way to use %. 2nd question - is there any way to hide certain rows in a table based on the value of a column in a row? Thanks in advance for the help.
A bit late but ...
You can set the columns to relative widths by setting the props.columns.n.width parameters to something like
- columns
  - 0
    - width: 1
  - 1
    - width: 4
  - 2
    - width: 2
to give relative widths of 1, 4 , 2.
Specifying strictWidth changes the way it works:
- columns
  - 0
    - width: 1
  - 1
    - width: 4
  - 2
    - width: 120
    - strictWidth: true
This will force column 2 to 120 pixels (although I didn't specify 'px' in the width) and columns 0 and 1 will adjust to fill the rest of the available space in a ratio of 1:4.
