Perspective Table excel report
I wonder is it possible to get an excel report from Perspective table info? someone just click on button and export all info to excel file?
Slap a button on the view, grab the dataset from the table and run it through system.dataset.toExcel: system.dataset.toExcel - Ignition User Manual 8.1 - Ignition Documentation and system.perspective.download system.perspective.download - Ignition User Manual 8.1 - Ignition Documentation
Stripped example from a working application:
tableDS= self.parent.getChild("Table").props.data
excelBytes= system.dataset.toExcel(True,tableDS)
fileName = 'TableExport{}.xlsx'.format(system.date.format(system.date.now(),'yyyMMd_kms'))
system.perspective.download(fileName,excelBytes,'application/vnd.openxmlformats-officedocument.spreadsheetml.sheet')
Thank you. It works.
I get an error on the line that calls the toExcel() function:
Error running action 'component.onActionPerformed' on DataSetPlayGround@C/root/Button: Traceback (most recent call last): File "<function:runAction>", line 13, in runAction TypeError: can't convert [9, u'Test'] to com.inductiveautomation.ignition.common.Dataset
The data type from the DB is an nvarchar. Is there a simple way to strip the unicode character u off the string?
Don't. It isn't really "there". It is an artifact of repr() operations when printing complex objects.
What it means is that you tried to supply something other than a list of datasets to the excel conversion function.
Ok,
Here's my code:
results = system.db.runNamedQuery("CAT/Material")
self.parent.custom.result = type(results)
spreadSheet = system.dataset.toExcel(True, results)
filePath = "C:\\Users\\...\\Data Exports\\results.xls"
system.file.writeFile(filePath, spreadSheet)
The type is a PyDataset, just found that out.
The error is the toExcel line.
Pretty basic query, 2 columns, 9 rows. I followed the docs for this function...oh, hang on, think I just saw something... I realized I was missing the [ ] around results. No error this time but I didn't get a file either.
This is a Perspective topic. Writing a file like that happens in the gateway. Are you looking in the gateway filesystem?
@pturmel I moved this topic to this thread, since the OP has already solved his issue and there are probably going to be more questions.
Thanks!
