Perspective table filter results text change
I have a perspective table component and I changed the header to a darker color and when I enabled the filter I changed that to match. Unfortunately, that means that the filter results text is hard to read. I used DevTools and was able to find where the color was set and changed it in the stylesheet but it did not work. I am sure I am just having a massive brain cramp and for some reason cannot find it. I applied it here, but not sure that is where it should be.
.psc-itemTrackerTable .tableFilter .filterResults {
    color: #FFFFFF;
    font-weight: 600;
Check dev tools again to see if your selector shows up and see if your css prop values are being overridden (they're striked through) . You might need to add !important
To make that CSS work you'll need to add the itemTrackerTable class to the table's props.style.classes
If you're looking to have both the search bar text and the results be the same color, you can alter your class a little:
.psc-itemTrackerTable {
	.tableFilter,
	.filterCommon .ia_inputField {
		color: #FFFFFF;
		font-weight: 600;
Thank you for that I was just trying to put that in the wrong place thank you!!!:grinning_face:
