Perspective table font color
I'm trying to change the fontColor of rows in a table using script
I have tried setting 'fontColour' without success
My script looks like:
	def contrast_colour(rgb):
			rgb_values = rgb[rgb.find("(") + 1 : rgb.find(")")].split(",")		# Extract the RGB values from the string
			r, g, b = map(int, rgb_values)  									# Convert string values to integers
			# Calculate the contrasting color
		 	cont_r, cont_g, cont_b = 255 - r, 255 - g, 255 - b
			cont_colour = "rgb({},{},{})".format(cont_r,cont_g,cont_b)
			return cont_colour
	lst = []
	try:
		value = [v for v in value if v['attribute'] == self.getSibling("tblAttributeSelector").props.selection.data[0].attribute]
		for row in value:
			display_colour = row['display_colour']
			r = {'value': {'attribute_value': row['attribute_value'] },
				 'style': {'backgroundColor': display_colour, 'fontColor': contrast_colour(display_colour)}
			lst.append(r)
		if len(lst) == 0:
			self.meta.visible = False
	except:
		pass
	return lst
Some advice would be appreciated
Might need to inspect the element to confirm the selector you need, but maybe you should try setting color.
Some documentation on your code would be useful. What is the format of the input data and what do you want back.
As far as I'm aware, there is no "fontColor" CSS property. It's just "color".
