Is there some way to change the Header font size in the Table component?
Trying to create a table that holds the same information and fits both in low and high resolution.
In the column, there is a style for header or footer where you can change the font size. I think you have to change the size for each column. I had to use the correct name for each column to match my dataset.
Thank you very much Jay. Your solution works for me.
