Perspective Table Highlight Index
Hello,
This might be a no brainer, but I'm struggling with it.
With a perspective table, is it possible to get the index of the mouse over highlighted row?
For example in this scenario, I wanted to fetch the right table row index when hoovering (row highlighted in red):
Any ideas?
Thank you.
It is my understanding this cannot be done without some tricks (JS injection or custom module).
The only thing you can do is get the selected data, not the hovered data. You'd have to at least click on the row.
Nevermind, this thread might prove handy:
Thank you for the link, but unfortunately is a no go.
I was trying to get around the lack of drag & drop, had almost everything done (highlights, cursor, ...), but I need to know the destination index.
I feel it's a big handicap when you want to use ignition for something a little more complex then visualization or simple table operations.
Again, thank you for the link.
I'm actually using Victor Declercq solution with very slight modifications, and so far things are looking good.
I'll post an update with the final result, acceptable or not!
i didnt see the orginal question, but should be possible, with JS. but seems you already found one of my solution that will suit you better :slight_smile:
