Hi, I want to rename the column header of the Perspective table. The Data of the table is from Tag Dataset.
I want to rename the column headers and rearrange the column order : Id, Name, Style, Data, Internal id.
Scroll down further on the PROPS and you’ll see a section called “columns”. Start adding columns. This is where you define the specifics of which columns you want to show and how to format them along with the title.
In the “field” key, enter the name of the column from your dataset. Then in the header/title key, type in what you want the user to see as the column name.
@drojas thanks
