I have a perspective table with a json dataset, I want to remove rows that I have filtered from the dataset.
Removing one row is easy as the selectedRow property in selection is populated but when I have multiple rows selected, the selectedRow property only has the last row i clicked, not the list selected.
selection/data and filter/data properties only have the selected row values, not the row numbers
Is it possible to get the list of selected rows numbers from the table?
I'm reading an excel doc and populating a dataset into a table. I don't have any unique identifiers and I was hoping to use the row index if possible, i found another post that manually creates the index based on counting the rows. I might do that as I delete items from the table, the row numbers will change.
Right, the rows need to be enumerated so they have some sort of index to identify the rows to be removed explicitly. The implicit row numbers from the component would not be ideal.
