Perspective Table - Show Dropdown in Label Column Only When Action Column Has Value (Ignition 8.3.8)
Hi Everyone,
I'm working on an Ignition Perspective project (Version 8.3.8) and would like to know if the following requirement is achievable. If yes, could you please guide me with the recommended approach?
Requirement
I have a Perspective Table with the following columns:
Action
Label
Initially, all rows are empty.
Example:
Action Label
At runtime, a user action (button click or another event) updates the Action column for a specific row.
For example:
Action Label
Start
Stop
Expected Behavior
If a row's Action column contains a value, the corresponding Label column in that row should display a Dropdown component.
If the Action column is empty, the Label column should remain empty and should not display a Dropdown.
This must work dynamically on a row-by-row basis.
The table may contain 250+ rows, so the solution should be scalable and not require manual configuration for each row.
Example
Action Label
Start [Dropdown]
(Empty)
Stop [Dropdown]
(Empty)
Questions
1.Is this achievable in Perspective?
2.What is the best way to conditionally display a Dropdown based on another column's value in the same row?
3.Any examples, best practices, or documentation references would be greatly appreciated.
Ignition Version: 8.3.8 (b202671409)
Thank you!
You could use a embedded view in the "label" column with a dropdown.
That embedded cell will receive all the row data and dynamically display or hide the dropdown.
See the docs for guidance.
Hi @RodrigoR ,
Thank you for sharing the documentation link. I went through it and implemented the embedded view with a dropdown as you suggested. It's working well and helped me achieve what I needed.
There are still a few minor performance issues that I'm currently investigating. If I'm unable to resolve them, I may reach out for your guidance again.
Thanks again for pointing me in the right direction. I really appreciate your help!
