I have a Table that is getting its data from a Named query, the table has 1 DateTime column, when testing the named query returns the datetime as shown in the SQL server, no problem so far…
In Perspective I inserted a table and added a Query Binding type to show the data from the Named query, but the table DateTime column doesn’t match with what is in the SQL server, is off by 3 hours…
Here you have two queries that i use for some data log one to create my table into my db and another to write the logging into the table. If i retrieve the data into a perspective table the date stay correct.
But DB and gateway are on the same computer.
i suppose that you have set the column properties correctly ?
The only way I could fix the time difference was by changing the Project Timezone to match my SQL Server Timezone by going into the the menu options: PROJECT/Project Properties/Perspective/General/Project TimeZone.
It appears that the Timezone change updates only during the Gateway start up, when I changed the Project timezone I didn’t see the changes reflected immediately, only after stopping and starting the gateway.
