I’m using a named query to supply the data to my table. In the dataset the format looks correct, but in the table it does not. How can I fix that?
Consider using ‘columns’ property on table component. Under column configurations, changing ‘render’ property will allow you to implicitly render data as certain data type.
I had to add the column and name it appropriately in order for the date to work in the field property. Thank you!
change you columns[0].field to t_stamp.
It seems that render selection only works if there is a valid field assigned.
Thanks for some reason I tried that originally and it didn’t work. It is working now. Appreciate the help.
