Hi, I'm using the table component in perspective to show the my named query result, In this my "assign_date" column information not showing the result in correct format.
Actually it need show the date & time.
Please give me some suggestion. Thanks.
- For each column set
columns.x.fieldto the exact name of the column inprops.data. - For the
assign_datecolumn set,
columns.x.field : assign_date
columns.x.render : date
columns.x.dateFormat : YYYY-MM-DD HH:mm:ss(or whatever you want).
Many of the column properties don't work unless you specify the column's field property.
Thanks!
